Also the problem could be a loose pin in the fuse panel. I see that alot. Sometimes you can use a small pick and spread them sometimes you have to change the whole panel as the pins do loose their tension. To change the whole panel is easy if you need to.
  • 4 weeks later...
Is that a circuit breaker or a relay? It is still blowing. It only blows when the ambient temp gets to 70 or higher. It has been at the dealer for 2 weeks now and they have no clue. I think it has to do with the hi pressure cut off on the a.c. It looks like i will have to bring it back to them in the spring time when it gets hot because they say the condition isnt present now, and the can not fix whats not broke. what condition would make that blow?
