I have a 2008 Mack with an MP8 in it. Trucks starts up and runs fine then while driving down the road goes into limp mode and wont go above 20mph. A previous mechanic scaned it and said it needed the oil sensor inside the pan they did that and we still have the same problem. That is why I am now looking at it unfortunately I do not have a scan tool so I cant read the data. Any help would be awesome Thanks again!
https://www.bigmacktrucks.com/topic/37639-mp8-goes-into-limp-mode/
Pop the connector (twist style) off the LHS of the oil pan, if oil made it through you'll be needing the updated oil sender/eop sensor and pigtails. Same goes for the eop, if it's letting oil pass through the sensor, it's fubar. I've done several of these and it requires a jumper harness to be installed between the sensors and engine harness.
Edited by Graves
  • 6 months later...
  • 3 years later...
Have a 2011 Mack Granite with a mp8 engine. When I bought it the one wire on the small fuel filter was not connected but never a problem. Had it serviced today and the tech plugged the wire in and now I have a fault light. Will it go into limp mode?
Edited by Bill P
