I have 2 Mack B30's I have done a lot of prep to get them running but can't find a good way to turn back and forth with lubricant. I have put penetrating oil in the cylinders, let is sit for week or so, tried to turn the engine with a breaker bar on the front bolt (can only turn in one direction), tried the starter, tried to pull with another truck (the clutch slipped).
I would appreciate any help. I am thinking about filling the cylinders with kerosene and / or penetrating oil, then letting sit again, them try to turn over.
https://www.bigmacktrucks.com/topic/3769-help-unfreezing-a-6cyl-gas-331/
Jack up the back wheel on one side put it in high gear and bump it back and forth like that
  • 1 month later...
several shots of marvil mystery oil in each cylinder then air let sit a day or two then repeat. I have freed several this way. good luck
try a can of sea foam oil, put it down the sparkplug holes, let sit, then try and crank it with two batteries.
After doing what is suggested in above posts, I chain up my skid steer loader to the rear frame of the truck against the spill guard of my forks tightly. I then gently rock the truck back and forth with the truck transmission in low gear. Most times a stuck engine will free up over a period of time and with this method, you don't break or burn up parts.
I've had four trucks that I've done this with and each time has worked well. I use ATF in the cylinders.
