hey all,
My 95 Mack CH 613 with a 350 9spd Eaton has 40,000 rear diffs and spoked Dayton wheels front and back.
I have the opportunity for a set of used aluminum Uni mount rims Budd rims.
My thought is on the 4 rear hubs are they a Mack or an Eaton thing.
Also the front axle, is it a Mack axle or something else?
thoughts?
Glen
Edited by Glensts
https://www.bigmacktrucks.com/topic/37921-95-ch-mack-hubs/
I think mack is the only one who has the drop center on the front axle beam and the rears should be mack if they have the toploader carrier on the rear axle. Do a lot of research Im having to swap a whole different front axle beam under my truck just to go to hub piloted front wheels best way to know what you need is to get the bearing numbers that are in the existing hubs to know what will interchange with your axles.
https://www.bigmacktrucks.com/topic/37921-95-ch-mack-hubs/#findComment-268702
  • 3 weeks later...
