R mack with five speed. In gears 4 and 5 around 30ish mph I have a vibration and doesn't matter if it's in gear in neutral or coasting with clutch pushed in I have this vibration. Sitting still revving motor or running in all other gears including 5th over 30mph it's smooth. Any thoughts? Thanks
https://www.bigmacktrucks.com/topic/37941-vibration/
how much is some on the carrier? at higher speeds, the carrier will bounce a lot more than slow.
The carrier is not expensive, its the gettin to it part that sucks
This from experience
https://www.bigmacktrucks.com/topic/37941-vibration/#findComment-268856
