Yep, the mechanical detach trailers have to have em, they have rollers on the front of the apron to help get you under the trailer. Sucks to do with camelback it is sooooooo much easier when you can dump the air ride and drop the truck 4".
https://www.bigmacktrucks.com/topic/37986-frame-ramps/#findComment-269300
Air bags are nice with a regular trailer too.
https://www.bigmacktrucks.com/topic/37986-frame-ramps/#findComment-269314
Damn! Now that's a frame ramp!
https://www.bigmacktrucks.com/topic/37986-frame-ramps/#findComment-269998
  • 3 weeks later...
these were on MH's set up for low beds...
BC Mack
Seems you could get nearly anything off the ground......
https://www.bigmacktrucks.com/topic/37986-frame-ramps/#findComment-271922
when trying to get a HEAVY Cozad or Arnies lowboy goose neck off the ground those long ramps are a MUST and on ice there still not gradual enough. I used to FLY out from under the goose neck in slick conditions at times it would take the lite cord and sever it, from one end or the other, and hyperextend the air hosed.....don't miss those days!
https://www.bigmacktrucks.com/topic/37986-frame-ramps/#findComment-272193
