So my 88 superliner the headlights wouldn't come on this morning. The flash to pass switch works and they light up but not the main switch. The switch connections look good on the back and the relay is working. Any suggestions?
Typical corroded dimmer switch on the floor. Give it a swat with your foot. Might shake it loose and it will work for awhile.
Check for power at the dimmer switch plug. I've seen the power wire get corroded from the heat of power running through the wires and over time, you loose connection.
Ok I found that on the back of the switch there are supposed to be to power wires coming into the switch. The power wire on the side that the headlight wire is on has no power. If I jump the power from the the working power wire to the one that's not working power wire the headlights work. I'd like to find why it has no power but would rather no start tearing my entire dash apart. Any ideas why it lost power?
Does the "dead" power wire get it or give power to the switch?
Wiki section on this site has the wiring diagrams for SuperLiners.
Replace the dimmer switch first. Get a new 30 amp circut breaker- first one on the left in "glove box"- may seem to work but will get weaker every time it opens.
Baxter, does everyone just jump the one side to the other to repair it? Sure wish I had a wiring diagram....eeerrrrrrr
Dogcatcher put in a seperate switch just for the headlights on his. One of mine is bad but I have not started working on it yet.
previous owner did that to Super Mutt,too.Never had trouble with any of my others.
