Dual straight exhaust near done
Its a four inch exhaust the engine has flex pipe coming from it to the pipe mounted to the frame then the Y pipe is mounted to the frame the cab is mounted solid on rubber bushings so not much flex there but I added stainless flex pipe from the rigid mounted Y pipe to the stacks so any flexing will be taken up between the Y pipe and exhaust stacks.
  • 3 weeks later...
New exhaust always looks good, 4" stacks should make that sucker bark for sure.
