Found some nice 9.00 X 22.5 tires to hold up my 'EF'.
The plan was to change the old split-rim tube-type with tube-less tires of the same size.
The ones I found are even steel radial.
Here is the issue:
The rims I have are for 11.00 X 22.5 tires and 'IF' (and that's a BIG if) I could get them mount, The sidewalls will be laying nearly flat to reach both sides fo the rim.
The 11.00 X 22.5 rims measure 9 in. inside-to-iside.
Here is the $64.00 question.
Can I get Dayton rims that are 7 in inside?
Daytons out here get you a funny look and a shake of the head, so I'm looking for some Eastern
input to get me on the right track! (Or any where else, for that matter)
Thanks Guys!!!
Packer
Keep a clutchin'
https://www.bigmacktrucks.com/topic/3819-900-x-225-wheels/
Here is the issue:
Thanks Guys!!!
Packer
For 11R22.5's you want 8.25 inch rims. Here in WI that size rim is a dime a dozen, whether Dayton, Unimount, or old type Budd.
Those 9 inch rims are good for someone who wants to upgrade to 315/80R22.5's on a steer axle, I'm sure you could sell them easy enough.
Yes, I have seen 7" 22.5 Dayton rims, bought a set at a local junkyard once to use on a pusher axle.
https://www.bigmacktrucks.com/topic/3819-900-x-225-wheels/#findComment-19428
HK
Thanks for the info!!
I picked up some rims for 11.00 tires.
The inside- the-flange measurement is 9 in.
I assume that these are 8.25 inch wheels.
I've mounted 11.00 X 22.5 tires on them and they work well.
The 9.00 X 22.5 tires would never air up on these wheels.
Way too much room to fill.
The 7 inch wheel should work much better.
Now all I have to do is find some!
Dayton wheels in the Rockies are like hens' teeth - - - You've heard of them but never seen any!!!
Packer
Keep a clutchin'
https://www.bigmacktrucks.com/topic/3819-900-x-225-wheels/#findComment-19438
