I'm Needing Lots Of Help
So,
I've now got my first Mack truck, and must admit Idon't know the first thing about them. This one is a 1971 set up as a logging truck with a Prentice self-loader. For starters, I'd like some help identifying the model, etc. On the door frame was R763S and a serial number of 1574. Is that enough for soemone out there to tell me a bit about my truck...what model etc? And if you could steer my in the right direction as to where I might get some manuals for this truck, I'd be obliged.
thanks,
~martin
1965 Mack B-74, dump
1974 Mack R, logging w/Prentice self-loader
www.somewhereonthemountain.blogspot.com
What you have is an R-700 model, the 63 designates the driveline. The following numbers are the sequential serial number. I suggest you contact the Mack Museum with this info and request the build information for your truck. It may tiake a little time but what you receive will certainly be beneficial.
I suggest you forward a donation to the museum.
Doug
Interested in Old Trucks? Check out:
www.antiquetruckclubofamerica.org
  • 3 months later...
Doug
The mack museum can tell you anything you want to know about your truck when it was built. Including who it was built for. They will most likely send you a build or line sheet if you ask them Good Luck. An R-700 was one of the largest R-models built
And the BEST! Now don't think I'm biased or anything like that.......
