I have seen quite a few alternators cause this. Check all battery, ground and power connections. Make sure you check the frame ground inside the left frame rail by the engine and the power and ground connections on both sides of the cab pass through by the steering column. I have seen a lot of the above loose and causing voltage fluctuations.
