  • 2 months later...
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
Hi Grant, i havent been able to get on here for a while to reply to you. The reason your FR has a hole in the LH chassis rail for steering is because it is an R model chassis, if it was an F model chassis there would not be a hole for steering and your front front spring mounts would be totally different from L to R, what you have is a standard Aussie built post 71 'F' model which is actually an 'FR700R', i.e. R model chassis. Regards jeffro.
https://www.bigmacktrucks.com/topic/3834-f-model-pics/page/3/#findComment-28219
Hello, it must have been a heavy duty version? as the chassis is deeper than the R model i have, the R model i pulled the cab off and the other R that i wrecked had a much smaller chassis, the left and right side front spring mounts are the same, i am using all the suspension out of it as i must assume it would be higher rated than the R600 stuff? the front axle is a 532
i just picked up power steering off a valueliner for it, so i wont have to turn the wheel a million times to turn her, specially needed when backing the double roadtrain up to that third trailer.
regards Grant
https://www.bigmacktrucks.com/topic/3834-f-model-pics/page/3/#findComment-28291
Thank you,I've been approved and signed on the dotted line,and looked at the pictures :D
I do keep a can or two of spam in the truck,in case I get snowbounded or something-hope they don't find out and kick me out. At least i've already looked at the pictures! ;)
Nothen wrong with spam and on top of that Obana has been eating it so i will eat more of it my self. glenn
https://www.bigmacktrucks.com/topic/3834-f-model-pics/page/3/#findComment-28296
