Bad speedo head is my first thought. If you have a diagnostic computer w/v-mac3 on it or prolink you should see mph on it. I would think if there was anything wrong you would have a fault and the odometer would not be working. If the mph is still off then the tire rev setting needs to be programmed with correct value.
https://www.bigmacktrucks.com/topic/38611-no-speedo/#findComment-276189
