Not really a new member but been a long time since I been on here. Still got my Superliner, although at the moment it's awaiting new trans and the neway is shot, so it's gettin a kw 8 bag cutoff, bought a 96 cl613 in November as a late birthday present to myself, 454, 18 speed, full double frame, 46k rears, has an issue or 2 that I'll post about in the correct category. Then in November I thought, what will I get myself for Christmas?? So I got a 98 kw w900l haha. But anyhow I was mad at stuff breakin last time I was on here, and I guess I just finally realized, whatever it is if you're gonna use it, it's gonna break ha.
THE MILKMAN DID IT.....
https://www.bigmacktrucks.com/topic/38634-im-back/
Welcome back and hope you get your idle problem fixed on your CL. Hope the 900 makes you a good truck.
https://www.bigmacktrucks.com/topic/38634-im-back/#findComment-276364
Broken stuff can be really frustrating.
Everything made now seems to break way too easily.
You are probably sick of opinions BUT I would rebuild the Neway on the Super. There is way to much stuff to go bad or get out of whack on an 8 bag KW.
https://www.bigmacktrucks.com/topic/38634-im-back/#findComment-276388
I would love to rebuild the neway, but all the beams are shot, and the 8 bag is all rebushed, both rears are fairly new, and all I have to do is cut and weld the frame, also has 3:73 as compared to 4:10, and also hub piloted wheels instead of stud piloted.
https://www.bigmacktrucks.com/topic/38634-im-back/#findComment-276397
