Hi!
i probably need to switch out the spoke rims with the plate type of rim, and after alot of research im still not completely certain what needs to be done, so ill ask here.
is it enough to replace hubs and brakes? or must i replace the spindle etc too?
if anyone here done this or found a description how its done, then i would appreciate if you let me know, would help me out a ton!
regards, kim
thanks for answering! i just like the looks better, atleast on the project this is planned for.
so thanks for confirming that it can be done with hubs and brakes, it feels alot safer buying stuff when you know it will work out right! :-)
cheers, kim
