Our cl started makin noises the other day in 7th and 8th gear when pulling, figured for sure transmission was goin out, it's a t2180 and the shop quoted me at 10k to do it, well we ended up runnin the cl for 2 days after the noise statted(might as well make pieces now)and then took it to the shop. Here the rear rear went out and was makin noise near top end. So that's a good bit cheaper than transmission ha.
THE MILKMAN DID IT.....
https://www.bigmacktrucks.com/topic/39088-what-a-relief-sorta/
Wow 10 k for a transmission I did mine myself replaced 2 bearings had about $250 in it by the time I was done.I hope they treat you right on rear end if you get a used or rebuilt one you can change it easy enough in your driveway if you had too
https://www.bigmacktrucks.com/topic/39088-what-a-relief-sorta/#findComment-280833
