07 T600 475 Isx Cummins 10 speed and 3.55
5/30 489 Miles 89.891 Gallons 5.4 MPG
5/29 1249 Miles 217.600 Gallons 5.7MPG
5/23 1355 miles 213.598 6.3MPG
As the numbers got lower I am oversize and had a massive headwind Friday and Saturday from Il down to Ar. that is 65 mph for the most part.
Also run close to gross and different terrain all the time
https://www.bigmacktrucks.com/topic/39255-fuel-milage/page/2/#findComment-291822
bbigrig, be careful with anything shorter than a 230 in a CHU, anything larger than a 56" sleeper and you wont be able to pull a reefer without being really close to the cab, "really close". There are several CH's, not CHU's i have seen around here in the 220-240" wheelbase range with 60" and 70" sleepers and rear mount exhaust that I wouldnt want because Id never be able to move anything I wanted. I know theres a logging company here with a 60" mid rise on about an 06 model that I think was a 224 wheelbase and with a flatbed behind it theres barely 24" from the cab to the trailer. I prefer a nice comfy 4-5' between the truck and trailer, 6-7 is even better,lol. Of course with a 48 or 56" sleeper and side mounted exhaust you get some more space freed up back there. i think Id want a 56' flat top with side mount 7" exhaust and about a 270-280" wheelbase!
https://www.bigmacktrucks.com/topic/39255-fuel-milage/page/2/#findComment-291917
2015 titan with 55,000 miles on him. I gross 91,000 lbs. Im empty for about 1/8 of the miles I put on. I make 8 stops to fill the truck and I average 5.7 mpg or 6.3 mpg if I keep my idle time under 10%. And I run interstate the majority of the loaded miles at 70mph. But I do burn a gallon of oil to every 2700 miles. Otherwise zero issues with this truck.
https://www.bigmacktrucks.com/topic/39255-fuel-milage/page/2/#findComment-292012
A Gallon of oil every 2700mi.....on a new truck? Holy crap man!
https://www.bigmacktrucks.com/topic/39255-fuel-milage/page/2/#findComment-292287
I've always ran rotella and I have a e7 with a million miles and no new bearings and that don't even use oil. But I figured on this one I'd have Mack do the service so they use their oil. I may be switching to rotella on this one........
https://www.bigmacktrucks.com/topic/39255-fuel-milage/page/2/#findComment-292314
