You didn't need to remove heads to remove can but the lifters need to be raised to allow can to side out you can do this with either magnets or possibly take a wire coat hanger cut it and carefully hook the top of the lifter by turning the coat hanger in to it then after you raise it bend the remaining coat hanger so it stays in place
https://www.bigmacktrucks.com/topic/39458-e7-460-1999/#findComment-284316
I'm doing inframe on it to cause not sure how many miles on it. Thanks for the info btw does the lifter come out to the bottom? Might need to replace couple as cam lobes on cyl 3 5 was damage also is it normal for the eup spring to rub on the inside of eup rollers. Thanks again!
https://www.bigmacktrucks.com/topic/39458-e7-460-1999/#findComment-284321
There is tools to help remove the cam, They are plastic rods with magnets on the end to hold the lifters up away from the cam and a rubber ring that slides down against the head or block if the heads are off. Also a set of plastic protectors that wrap around the cam that protect the bearings. They snap on in two locations to make the lobes the same size as the bearing journals. Grease on the lifters did not work for me, as soon as a little bit of oil gets on the lifter, down it comes. Magnets worked best.
https://www.bigmacktrucks.com/topic/39458-e7-460-1999/#findComment-284424
