Are you going to use the 3 leaf springs from the newer F model if so it should ride better. I did that to my 72 R model and rode better than the stack springs, looks good.
The stack spring pack is the same on both... The donor truck was a 1970 model. The axle pictured is the one I am installing.
https://www.bigmacktrucks.com/topic/39481-feeling-inspired/#findComment-284707
I like how you used the trailer to put some weight on the back
Yeah that worked out pretty good I blocked up between the trailer frame and the tractor frame so the trailer acts as a lever to support the front of the tractor almost like I knew what I was doing[emoji12]
Gregg
https://www.bigmacktrucks.com/topic/39481-feeling-inspired/#findComment-284954
