Not yet, tentative plan is to hop a bus May 8... I'll be coming through IN, if I need a kennel can I count on you? ;)
  • 2 months later...
Did you get the truck home yet?
Yes, its home... leaked like a sieve the entire way. Sheppard guy tells me he needs more info. I know its a 392S, but the series number must be hidden behind that Mack specific pit man arm extension.
Here are all the part numbers necessary to fix input seal on those cursed axle mount Sheppard boxes. Note, these are only applicable to the lighter 392 series boxes used on 10,500-12,000lb axles:
Mack part numbers:
8148-2370301 square O-ring $3
8148-2351251K hy-pressure input seal $30
8148-2350961 salt seal $9
8148-2351301 dirt seal $7
Save somebody a lot of time and grief with the counter VIN monsters.....
Sheppard told me you could reuse the dirt salt seal if they aren't mangled or hard.
