My can clutch on my CV713 2006 stays on. I replaced the air solenoid valve, still not working. I should have checked the plug before buying a switch because I have 12volts getting to the solenoid but no ground. The ground comes from the ecm whenever called for fan off. Any suggestions.
https://www.bigmacktrucks.com/topic/39537-fan-clutch/
i am having the same issues currently with a 05 CV-713, E7-427 engine.
if the temp sensor tells the computer the engine is running hot, will it shut the AC off?
i have disconnected the AC high pressure switch and the fan is still locked up.
but if i suppy a ground to the air switch negative side wire, the fan will shut off.
https://www.bigmacktrucks.com/topic/39537-fan-clutch/#findComment-288466
  • 3 months later...
