Recently replaced my truck cab, and now my engine will turn over but won't start. Keep getting code 6 4. Truck is a 2001 Mack CH 600 with a E7 427. Have already repeatedly check the grounds. Any ideas or suggestions?
http://www.bigmacktrucks.com/index.php?/topic/27990-trouble-code/
I understand most common causes are a shorted wire or wires to the ECU's
There are a pair of wires that are twisted together. That is done to cut down or eliminate frequeny interferene from other systems. The link above give a few tips to look for, including miss matched processors.
I'll stick with my pre computerized units.
https://www.bigmacktrucks.com/topic/39558-6-4-code-on-e7-427/#findComment-285524
