We are a small company only running 2 trucks and we've spent tons of money on our 2011 mack. We've only had it for 6 months and it's been back to the dealership 5 times because of problems with the dpf system. We finally got all that straightened out and now a problem with the lights. Everything works fine when the lights are off. When the light switch is turned on the left turn signal indicator on the dash stays on and all the left turn signals stays on. No flashing just bright. We changed the signal switch and no luck. Soon as you turn lights off the indicator goes off and everything works perfectly. Please help. We can't afford to keep taking it back to mack to have it fixed
https://www.bigmacktrucks.com/topic/39632-2011-pinnacle-nightmare/
Unplug or take out the left turn lights one at a time. If the problem goes away its in the bulb or led unit. I have seen this before.
Might not be this, but easiest spot to start. Next is a short in the wiring. Can be a little more difficult to find.
Good luck
O , and Welcome to BMT
Keith
Good luck
After you check the bulbs or LEDs check the grounds for those lights too.
My granite had similar problems last year. It was the wiring loom that goes from the front of the frame into the hood. It had chaffed through and was shorting the left light cluster.....
I appreciate the advice guys. I found the problem. Believe it or not, the problem was the bundle of wires that go from the firewall under the cab to the back of the cab into the female plug for the trailer pigtail. Someone had spliced it and it was dirty and wires touching.
  • 2 years later...
Bdenny,  I'm actually buying a 2011 Pinnacle in a couple of weeks.  Everything I have researched so far is positive but haven't had a chance to get feedback from drivers who actually own one.  How has the truck worked for you since you've had?
Have you had to change the Injectors and Cups yet?
Is there any advice, tips you can give me to help me stay ahead of any potential problems?
Thanks for your help.
