hello every one,mack truck,yearmfr-2004,engine model-Ac350,hp350,engine can not generate anough power to pull the truck,wastgate actuator on down steady and air supply hose to the wastgate actuator disconnected and does not hold down anymore,stay back in position,what could be the cause? and they are fault code present in dash which i didn't know the root cause,bellow is fault code;5-9(ASET CEGR)MASS FLOW, 5-8(ASET CEGR)EGR TEMPERATURE, 3-5 (ENGINE BRAKE OUTPUT #1), 4-2(FAN CLUTCH OUTPUT),Can all thise code make the truck to loss power both hill&even surface,any help,advise or guide will highly appreciated.
https://www.bigmacktrucks.com/topic/39766-engine-power-lossfault-code-dieply/
May point you in the correct direction, gives you possible causes for the blink codes. Paul
http://collision.alldata.com/online2help/techRef/Powertrain_Trouble_Code_Charts/Mack/V-MAC_III.htm
The 5-8 and 5-9 codes are most likely a bad mass flow tube which is common. It comes as a calibrated assembly with a module that bolts behind the EECU. Is the fan clutch staying engaged at all times as this will cause a power loss also.
