Ive posted before on my vibration issue im chasing ( for years now). It has changed recently and now consistently the same. I wont muck it up with all the back ground so I will start fresh and will keep it simple........ Ch 613 tractor.
- I have a vibration, empty and loaded, between 20 and 30 mph. its worse when heavy on the throttle. Give me your first and best guess.
Thank you.
https://www.bigmacktrucks.com/topic/39868-a-vibrator/
Same rpm in any gear?
Clutch in or out make any difference? Paul
https://www.bigmacktrucks.com/topic/39868-a-vibrator/#findComment-288400
TAKE A TAPEMEASURE AND CHECK DRIVES FRONT VS, REARS FOR HEIGTH AND CIRCUMFRANCE SEE IF ANY NOTABLE DIFFERANCE, COULD BE A POWER DIVIDER ISSUE ALSO!
YOU CAN ALSO TAKE A AXLE SHAFT OUT OF EACH AXLE AND RUN THE TRUCK UP THRU THE GEARS AND CHECK FOR PROBLENS WITH OUT HAVING TO PLAY SUPERMAN.
https://www.bigmacktrucks.com/topic/39868-a-vibrator/#findComment-288505
Same MPH regardless of gear ( or load). I varied the shift points to see if it changed with RPM. Its usually between 1200-1600 RPM. But always 20-30 MPH. I had some transmission work done. I had a vibration before, that was all over the place. Now its very consistant. I wonder if they had dropped or bent the drive shafts when they were out. What about rotating the shaft 180 degrees at the rear trans yoke? They did find a few things that would cause some vibration (trans mounts had elongated bolt holes, frame mounts were bad, input shaft was slightly bent).
https://www.bigmacktrucks.com/topic/39868-a-vibrator/#findComment-288595
It may have been bent before I bought the truck. The previous owner was swapping transmissions like he was doing oil changes. They kept tearing them up. Ive had the truck 8 years and never had the trans out. My trans now is actually out of a Freightliner.
https://www.bigmacktrucks.com/topic/39868-a-vibrator/#findComment-288615
