The 1st one is what I really need the round one I would like alone with the aluminum part the goes with the 1st picture. I'm missing one and what I made cut into the rubber before I adjusted them after I installed new hinges
Sorry about the pictures the sun is out today which is a 1st this week for the most part
post-17190-0-12503500-1431012787_thumb.j
post-17190-0-01102500-1431012807_thumb.j
post-17190-0-96931000-1431012840_thumb.j
https://www.bigmacktrucks.com/topic/39935-hood-parts/#findComment-289082
I just bought new rubber mounts/bumpers from the dealer. How do you get the print out of parts? I have tried to get the online access even tried to get Watts to order a part manual said they could not get it.
I am tired of searching for a part number with no parts book.
Robert
https://www.bigmacktrucks.com/topic/39935-hood-parts/#findComment-289391
I need the bracket that mounts the hood to the hinge. These are the 2 pieces, on on each side of the hood that the 2 bolts that go through the hood from the out side hold. Any idea on what they are called?
https://www.bigmacktrucks.com/topic/39935-hood-parts/#findComment-289415
Here is a print out that I had emailed to me from Manders for my Superliner 1 by vin number I was surprised that it shows a R hood but was told it is correct according to Mack support tech number. FYI Hoods are different for Superliner 1 vs Superliner 2 so make sure that you check the print out for your style of hood.
SUPER+LINER+HOOD.pdf
Robert
https://www.bigmacktrucks.com/topic/39935-hood-parts/#findComment-289420
