Looking to get a little more power out of our '86 superliner (4v) it runs ok but our 300's can out pull it. The anti-puff has been disabled,the pump has been rebuilt. I don't want to shorten it's life span, and also not so concerned with mileage on this one. Does anyone know what injectors, turbo to use, how about pump settings, and timing? Any help would be great.
https://www.bigmacktrucks.com/topic/39942-more-power-from-an-e-6-350/
The valves were adjusted a while back, it seemed to help, but not much. There is no turbo leaks, throttle linkage/cable all tight. It reaches governd speed with no load on the engine, 1900 rpm. I will be installing a boost gauge to get a reading. The company this truck came from was known for having the most gutless marks around.
