The A/C belt on my MH is squealing when I accelerate. I am going to install a new belt since I do not know how old is this one. I did a quick look last week and could not determine how to tighten the compressor. Does anyone have the service procedure or know how to loosen and put tension on the compressor/belt? What is the tension spec? Thanks in advance for the info.
Ken
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/
Ken, If your E7 is like my E6's, the compressor sits on a table. loosen the bolts that come up through the table into the compressor. There may be bolts that move the compressor to tighten the belt then re tighten the mount bolts. Check the table for cracks.
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-292358
Got into a can of worms today. I was able to determine how to adjust the tension on the A/C belt (4 bolts holding the compressor and 2 jack bolts). Anyway, after tightening the belt (was not that loose), I still had a squeal at high rpm so I was able to stand in front of the grille and listen as it continued to squeal. The noise was coming more from the driver's side (alternator side). So I checked the belts and they seemed loose. I was able to get the alternator belts tightened but now the squeal was constant and louder when I turned on the A/C. Next I loosened the belts slightly and still squealing constantly. Now I am thinking alternator bearing. When the A/C is energized, it puts a load on the alternator (is my thinking correct?). I removed the alternator but no side motion in the shaft. Anyway I am a going to have it rebuilt. I hope this will eliminate the squeal.
Any thoughts?
Ken
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293248
Belt could also be "glazed" from slipping on top of anything else. I'd personally put new belts on just for G.P. Paul
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293259
Belts look okay but I will likely put new belts on while it is down.
BTW, the belts were cool to touch. I figure if they were slipping, they would be warm. However the pulley on the alternator was very warm. Which leads me to believe the bearing is bad.
Ken
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293286
I know in the past, if the belts looked ok ie not fraying, chaffing, cracks, or dry rot, I've put a little dielectric grease on belts that squeal and that usually corrects it. It's worth a shot if you plan on getting new belts anyway.
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293290
Thanks everyone for the comments. I removed the alternator on Saturday and will be going to the rebuilder on Monday. Hopefully I will have it back on Tuesday. It is getting "crunch time" for Macungie. I know, I should have checked it when I returned from York. Hind sight is 20/20 as they say. Just been busy with the house in OH and farm property in PA. Seems there is less time to do stuff since I retired.
Ken
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293298
Update on the alternator issue. I checked on reman alternators and the cost is only a "few" dollars less than a new Delco which has a (1) year warranty versus a 30 or 90 days on reman. My alternator is a 22SI 145A and Watt has a 24SI 160A. The 24SI has dual internal cooling fans, otherwise they are the same (J mount, etc.). Unless someone states otherwise, 24SI it is. I can eventually have my old 22SI rebuilt and keep as a spare. The saga continues......
New alternator and belts and hopefully the squealing will be eliminated. If not, perhaps there is a mouse or two caught somewhere.
Ken
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293444
SUCCESS!! :banana: This morning I purchased a new Remy 24SI from Watt and installed it this afternoon. I also installed a new A/C belt but not alternator belts. The new belts were not long enough (although correct belts per parts book P642). So I reintalled the old belts (P652). I crossed my fingers and eyes and started the MH. Then with baited breath I turned on the A/C and NO SQUEALING!!! :twothumbsup: Did some snap accelerations and WONDEROUS!!
Only issure, I could not get the A/C compressor jack bolts installed so I used a pry bar and "snugged" the belt and tightened the anchor bolts. The new belt may stretch after some running.
FYI, the 24SI has dual internal cooling fans versus one external fan on the 22SI.
So if the Lord is willing and the creeks don't rise, I will be on my way to Mudcungie Thursday morning.
Right now I am happier than a pig in shit mud.
P.S. Barry - kudos to Terry for recommending the 24SI (and it was cheaper than a 22SI which was not in stock). Also, shop installed the pulley!
Ken
https://www.bigmacktrucks.com/topic/40343-mh-ac-belt/#findComment-293647
