If the red lights in the pressure gauges come on at low air pressure but no buzzer the instrument cluster needs to be replaced. The cluster is also a control module ( MID 140) so the cluster needs to be programmed or it will not work. The odometer and system time and date also need to be programmed.
Ditto
  • 3 weeks later...
