I took the front tires off of my B-67 with 22" rubber. It has been awhile since I changed them ,if the tires are not centered you cannot get them off the spoke they hit the fender. I do not know if wheel opening is smaller on B-67's with the short nose compared to B-61's. Anyone know ? Thanks Joe D.
https://www.bigmacktrucks.com/topic/40492-b-67-with-22-rubber/
Don't know for sure, Joe but from pictures I'm looking at looks like a totally different fender, cut shorter to match the hood. I wonder how many had 22" rubber?!? Seems that may be rare for a B67.
Gregg
Sent from my XT1254 using Tapatalk
https://www.bigmacktrucks.com/topic/40492-b-67-with-22-rubber/#findComment-293540
The whole fender is indeed shorter and I "believe" the radius of the wheel opening is slightly less.
A friend had a B-65 with the little larger fender than the B-67 running 24.5s and it sure looked like the tire would hit the lower rear part of the fender opening but it never did. It was really close!
https://www.bigmacktrucks.com/topic/40492-b-67-with-22-rubber/#findComment-293552
Thanks for the replies.If wheel is not centered it hits fender when trying to take it off hub. I always thought Mack had about the best engineering until this. Mack must have hired a Paccar Engineer for measuring B-67 wheel openings. Joe D.
https://www.bigmacktrucks.com/topic/40492-b-67-with-22-rubber/#findComment-293600
