Dumb question, but aren't both door glasses the same?
They are the same. Trace one then all you have to do is keep the inside vs. the outside straight and it will work... :tease:
I'd note where the glass sits in the channel (mark it somehow) so that you can get it in the right spot from front to back...I did that and had no problems with the installation.
Good luck.
Take out the good glass, tell the glass shop to make a copy and match the tint or clarity on it.
