Hello!
New to forum but have visited often. Longtime Mack fan with some basic questions.
What do the model names mean? For example B61, B81SX etc...
I am very partial to Superliners and LTLs. Have seen numerous pictures of B81 SXs, or anything with the flat "gravel pit" fenders. Any info will be absorbed like a sponge, you guys have so much knowlege!
Are there any publications availabe with this sort of info?
what model is this in the attachment? (if I did it right)
Thanks in advance!
https://www.bigmacktrucks.com/topic/408-mack-model-designations/
Hello and welcome to BMT! Glad you joined up! Here is some info I grabbed from www.oldmacksRus.com
Chassis Versions
What do all the letters mean?
These are the basic letters used
B - school bus chassis
C - flat face cowl for the addition of a delivery body
E - built for export
F - fire truck chassis
L - light weight or weight reduced by using aluminum components
P - platform chassis (single axle straight truck)
R - right hand drive. This designation was started in 1964 but right hand drive available
prior as option.
S - six wheel chassis (tandem axle)
T - tractor chassis
X - severe or extreme service chassis
Combine any of the basic letters to get a different chassis
PC - flat face cowl platform chassis
LST - light weight six wheel tractor chassis
SX - six wheel extreme service chassis
STE - six wheel tractor chassis for export
RX - right hand drive extreme service chassis
These are some odd versions
BD - school bus - no idea what the D means. Little more than 100 built 1955-1956
EWX - don’t have a clue on the letters but the picture shows a mean looking B83
built in 1965 with 3 drive axles
SX-C - six wheel extreme service chassis, may have been built in Canada
SX-M - six wheel extreme service chassis, no idea what M stands for
T-HS - tractor, don’t know about HS
T-M - tractor, don’t know about M
TPB - tractor piggy back
Now the fire truck combinations! The good guys at the Mack Museum and Harvey
Eckart had to do some “head scratchin” on these
CF - fire truck with Chrysler Corp. drive train
FA - aerial ladder fire truck
FC - fire truck chassis without fire body. This designation started in 1965
FCD - fire truck chassis with diesel engine without fire body
FD - fire truck with diesel engine. This designation started in 1964
FMD - don’t have a clue. Only built in 1963
FSW - six wheel (tandem axle) fire truck. This designation started in 1958 for fire trucks
but had been used in trucks prior to the B model series.
FT - fire truck tractor. This designation started in 1965 but fire truck tractors were also
built before this date.
Hope this helps!
https://www.bigmacktrucks.com/topic/408-mack-model-designations/#findComment-1841
I'd say the picture is a B81SX (of sorts). Variations could apply, but that's what it basically looks like.
Tall standing, 24" rubber, long hood gives it away.
https://www.bigmacktrucks.com/topic/408-mack-model-designations/#findComment-2024
