I'd make sure all ecu's software is up to date. Does everything look ok such as egr function, turbo vgt fuction, def pump operation, dpf diff. psi ok, etc. During the regen, do the temps and other specs look ok, after both regens the soot level should have been at least in the single digits. You may have to perform a scr crystal sublimination(sp?) to get the derate to clear.
https://www.bigmacktrucks.com/topic/40845-gu-713-mp7/#findComment-296137
