Hi. I have a 1979 RS600L. The headlight rocker switch will illuminate all the lights (clearance, markers etc) but not the headlights themselves. The lamps do in fact work as there is a momentary on switch on the dash that will light them up. Not sure if this is factory or not. But its only a momentary on... The dimmer switch has no effect on the main headlight rocker switch not lighting up the headlights..
Where can I start looking? Id like to replace the relay, but im not sure where it is. Im new to the R model. Any thoughts would go a long ways...thanks!!!
Kevin
https://www.bigmacktrucks.com/topic/40848-r-model-headlight-relay/
