They are hooked together so if one doesn't work then the linkage is broken.
Mine have always worked but until I put a new supply line to the valve now they will throw the blades off they go so fast. The original line was collapsed and limited the air volume. Usually something simple. I also pulled air motor off and cleaned the sludge out from the last 50 years. Basic maintenance is all that is needed.
https://www.bigmacktrucks.com/topic/40853-air-wipers/#findComment-296288
  • 3 years later...
