Call Barry at Watt's Mack. If the engine is a two valve Mack diesel,
they have a TEC brake for it. TEC makes a duplicate of the Jacobs
engine brake for these engines. Jacobs brakes are out of production for them.
If it's an R-400 with a Scania diesel, however, the TEC brake may not be the answer.
Good Luck,
Paul Van Scott
https://www.bigmacktrucks.com/topic/4089-r400-jake-brake/#findComment-21203
If the TEC brake won't work (call Barry),
you might try a PAC exhaust brake, which could
be very effective on this engine, and a lot simpler
to install.
We've had some real good discussions on this forum about
exhaust brakes. I think the long and the short of it is that
the valve train needs to be healthy before installing the brake
or you run the risk of piston/valve contact, which is rarely good.
Paul Van Scott
https://www.bigmacktrucks.com/topic/4089-r400-jake-brake/#findComment-21310
