Does the air system typically get enough lube from the compressor blow by? Is is good practice to add a small dose of some kind of lube once a year or so like ATF? This is for a 1978 R model that does not really have any air leaks but I just want to keep it that way and was curious about lube. And if so, where would I add it?
Thanks
https://www.bigmacktrucks.com/topic/41008-air-system-lube/
