Go wiht an MP8 and you are golden, the MP7 has a pressed bushing in the riod that aint the greatest but they are pretty darn good engines for 11 liters, the MP8 is a torque monster for a 13 liter, with the active torque management it seems like they pull harder the heavier you load them, the 505hp anyway.
https://www.bigmacktrucks.com/topic/41019-mp-engines/#findComment-297548
Mp's aren't too bad. Aside some small inherent design flaws of using just o-rings for seals that cause some minor fluid leaks they are pretty good. If you get one with the SCR be very mindful of the corrosive nature of DEF when filling the DEF tank. That stuff will corrode aluminum and copper instantly. So it will eat up wiring harnesses and sensors which intern throws codes for the emissions system. MPs have some power I can tell you that.
https://www.bigmacktrucks.com/topic/41019-mp-engines/#findComment-297788
