theres no problem in the steering dept but middle drivers scuff real bad at least they do up here hauling logs at 53000 kg plus but there is a freight line hauling 53 ft tri box trailers out of town with all MACKS with M drive
https://www.bigmacktrucks.com/topic/41042-tri-drive/#findComment-297510
a agree on the dump valve you will have a lot of scrubbing on your drives without it but you will probably have to put your first inter axle in when you dump your rear.
i have a steerable lift on my truck, better suited for my application than a tri drive. i bet that thing would be unstoppable in a straight line if you have cross locks on all three drives as well.
https://www.bigmacktrucks.com/topic/41042-tri-drive/#findComment-297856
Well, got the air suspension and dump valve all plumbed in. Moved the leveling valve to the mid rear. Lmackattack, that's where I got the idea for using the dump valve on the rear looking at all the newer spread axle trailers. I anticipated that I might loose traction with the rear-rear at no pressure that's why I spent the extra time and money finding an air lock power divider for the new axle.
I only use this truck for a hobby so I stuck with 54" axle spread so it looks symmetrical. You would probably have to go to a 60" spread on non-Mack axles. The new rear went in front of the original bogie. Its cheaper and stronger than adding frame to the back.(need to change 2 carriers if adding to the back). Here is a picture from a different angle.
Ill update again when the drive shafts are ready. With an air lock power divider feeding another airlock power divider the first jackshaft is just under 19" long :loldude:
post-12594-0-17731200-1437939422_thumb.j
https://www.bigmacktrucks.com/topic/41042-tri-drive/#findComment-297973
  • 3 weeks later...
