Correct me if I'm wrong....a spring suspension is rated mostly because of the springs. You wanted a higher rating you changed springs or added springs.
What about air ride? If I wanted to increase my rear axle rating what would I need to do? Bigger air bags? I want to add about 6000 to 10000 lbs (rating) to my drive tandems.
Thanx,
https://www.bigmacktrucks.com/topic/4105-rear-air-ride/
Thanx,
Hi Rob, there is more to it than just spring ratings. For instance the bearings, axle shaft sizes, housing structure etc...
You can add a heavier spring pack, or more leaves, or larger capacity air bags in your case but you could possibly be outside of the designers safety factor or window with modifications. I believe the brackets that support the air bags are heavier duty on a 44,000# suspension rating than that of a 38,000# rating, (for example).
https://www.bigmacktrucks.com/topic/4105-rear-air-ride/#findComment-21263
