Hi everyone I have a fuel filter question.91 mack superliner has a 425 cat. Primary fuel /water separator filter did not have a drain valve on it,neither did secondary fuel filter have one when I bought truck.mack dealer sells water/separator filters as does fleetpride without drain valve.i did find a luberfiner filter that did have a drain valve on it.my question is where does water go if you don't have drain valve.is the filter split so water can drain down? Which is the better filter?
https://www.bigmacktrucks.com/topic/41080-fuel-filters/
