Any one know the diffrence between the mack FA500 and the FA505?
Reason asking the better of the two A model trucks hubs were missing and a set from a B were stuck on it 10.00x20 I want to keep the smaller tire if possible the parts truck has 12.00 x 22
hoping the hubs would be the same
Robert
https://www.bigmacktrucks.com/topic/41269-axle-experts-question/
All I have on the FA500 is it is an 8000lb axle.
Here is a little info on the FA505 hope it helps. Paul
http://www.tyldenheritage.com.au/uploads/9/3/0/6/9306704/fa505.pdf
I have not torn into it yet I am hoping that with some new races and bearings I can fit the B hubs on or I guess I will becoming to see you Mike for the smaller hubs. The 22 make the truck really tall and Jackie likes the shorter stance. So far I think I have everything to get it running and I plan on a Chevy drive train ( 292 and a 4 or 5 speed) if the motors are shot. Thought about maybe using the engine from the F but I think it would be way to heavy on that little frame.
Robert
