is a yellow jacket's stinger-
I pulled it out of my leg after an unprovoked attack by yellow jackets while I was cutting the grass.
It doesn't hurt much, but this one still does.
Doesn't look like much on my finger,
but it's a nasty looking thing up close!
I never did see a nest, I was going to pour some gasoline in the hole and follow it with a match...sneaky rascals!
https://www.bigmacktrucks.com/topic/41297-what-this-is/
YEAH!!!! Them ground nesting one get real mad in a hurry!!! I guess the think a lawn mower is a tornado?? Had them chase me all the way back to the house and then the garden hose did not bother them much!!! I found their nest because the lawn mower was still sitting there!!! and YES the gasoline and farmer match works!!!
Brocky
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299517
Luck you :) all I ever got stung by was one of these.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299525
think that would be a honey bee yellow jackets and wasps don`t loose stingers. honey bees can only sting once
Not honeybees, definitely yellow jackets- I got a real good look at them. A couple of their bodies are still out there in the yard somewhere.
I might have caused the stinger to detach when I smacked it off me. I've been stung by them many times, usually while cutting grass, but this was the first time i've found a stinger stuck in me.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299527
I don't know if i'm lucky or not, but i've been stung 4 times in the last couple of weeks now, and I hadn't been stung 4 times in the last 20 years before.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299528
I got one nest in the eaves of the barn of something called White Faced Hornets and one giant nest in the ground of some all black bees. I prefer to just avoid them. I Fork Union I had mud wasps but quick work with Kerosene cured them. Hate Bees worse than Obama.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299529
well at least we know that one is done
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299530
They're persistent bast- uh, creatures too! The one that was stinging me on the ankle, I thought i'd never get that one off of me- stung me through my sock!
I've been back out there twice since looking for a nest and haven't seen a thing...except for that one, that crawled up into the hummingbird feeder.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299539
I had to go over to the brother in laws a couple weeks ago and eradicate a bald faced hornets nest in one of their trees they wouldn't go near it when I went right up to it and sprayed it down they thought I was crazy that's why my oldest niece and I get along well because Im her crazy uncle who isn't scared to try anything at least once.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299544
They're persistent bast- uh, creatures too! The one that was stinging me on the ankle, I thought i'd never get that one off of me- stung me through my sock.
Remember yellow jackets and wasps often will bite and latch on as they give you multiple stings. If you find the nest at first or last light when they are least active give 'em a good shot of ether, no fire needed. Usually will kill a nest with one good dose.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299545
I had an underground nest of bumble bees a few weeks ago. I got the big-assed (thats a highly technical term for "large") pasta pot and boiled up some water and went out there at night and poured it all down the hole. Figured the little bastards were done. Nope. Now I have Zombie Bumble Bees and a big 1' diameter brown circle of dead grass smack in the middle of my nice green yard.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299546
Interesting, never thought of using boiling water on the little buggers.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299548
:SMOKIE-RT:
As far as I know,there's NOT a valid reason in Nature for Wasps and Hornets,though I HAVE heard of Wasps doing a little pollenating when the bees are in short supply. That STILL doesn't redeem 'em in my opinion though-the only good wasp is a DEAD wasp. I'm glad you survived-those little buggers put me horizontal if I get stung.
Speed
:SMOKIE-LFT:
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299554
Hey Speed! Are you allergic to bee stings? I got stung here in the kitchen a couple of weeks ago, wasps made a nest in the vent over the stove and came in when I turned the light on over the stove to make coffee. 5 minutes later I didn't even feel it, but these yellow jacket stings still hurt now, and they stung me hours ago.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299568
Yeah-I've been pretty good at either stayin' away from 'em or taking the offensive and makin' 'em homeless. Seems like every car or truck I get ends up having nests in it somewhere-behing the headlight buckets,in the door jambs,in the wheel wells,hangin' off the underside of the hood...they must reproduce like little Guinea Pigs or rabbits-no matter HOW many I wipe out,there's a fresh crop every Spring.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299572
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299580
tis the season for them little buggers, been using about 3 cans of spray a week here between buildings and equipment, seems if you leave a machine untouched for more than 5 days you have to KILL them so you can reoccupy it.
them ground wasps are just nasty bastards! usally find them when moving cows,and they arnt happy after you run 50+ head over their nest! had another run in with them obamma wasps and they were angrier than a black panther meeting! they built a basketball sized nest under the loading chute after about the 4th. cow danced her way up the chute they came out like a bunch of looters in fergerson!so we tear gassed um with some exhaust off of a pickup and a chunk of poly pipe!
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299582
Tom,
Better get to a doctor and get one of them there "injection kits" that counteract bee stings. A good friend of mine almost died as a result of a yellow jacket sting. He had been stung several times previously without any issues but then one time he was stung and passed out. Wife called 911.
Ken
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299634
Tom,
The place on my ankle was infected looking this morning- I don't know if it was stinging me or biting me there, it was on the outside of my sock. I put some dollar-store equivalent of neosporin on it before I left. Still looks nasty, but it doesn't hurt any more.All last night it felt about like holding a lit cigarette on my ankle. Never had a wasp or bee sting do that before. And I didn't even gain any super-powers!
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299708
Better watch it close. Some of the bees have cross bred and the venom is similar to a Barn Spider / Brown Recluse spider bite. The flesh in the area will actually die and cause more dire problems down the line. Paul
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-299744
It was looking like this Monday morning
It seems to be healing, it doesn't hurt, and looks like this now-
There's one of the little bas-, uh, creatures now, on that hummingbird feeder.
https://www.bigmacktrucks.com/topic/41297-what-this-is/#findComment-300150
