sons just got a mack CF pumper ,needs a good cleaning on engine and undercarriage ,just concerned about water run-off from degreasing cause of their well is near by, is steam cleaning a better way to go and taking to a shop that does that,anything special to seal up on the diesel engine to prevent trouble?
https://www.bigmacktrucks.com/topic/41483-degreasing-engine-frame/
I have had pretty good luck using dawn or the purple power. Tough grease and dirt gets a shot of brake clean and wire brush or putty knife, like ed said it will take a while. I have not had any problems with water infiltration but I don't try and spray it directly into the air breather or oil filler. The engine is pretty sealed up unless you are missing or removed something from it.
If you use hot water it takes less detergent because it will help melt the grease loose vs blowing it off. I have a 2800 psi washer and do it on the concrete pad in front of the shop, I then pressure wash the debris into a row and clean it up and soap it down with dawn and let it dry so there is no oily residue.
Also the soaps I mention are bio-degradable and safe, in fact they use dawn on oil spill clean up.
Robert
You definatly need to be careful. When I first got the L model I regreased the hubs. After pulling them and cleaning out 30lbs of old grease they got power washed. About 2 weeks later dad said there was some oil in the houses water filter. It is amazing how far that stuff can move under ground.
