I have a random noise but only when running the pto and it only does it sporadically ! When it makes this noise it tries to turn the drive shaft. It is a loud gear clashing noise. I have 2 pto on this trans. So tomorrow I'm going to pull the 8 bolt pto to inspect. Any ideas would be appreciated. I have a couple of these trans laying around for parts. I know parts for them aren't cheap. So I'm hoping to tear it down and try to make a good one out of what I have. In the mean time someone find me a fuller 18 prefer a 20 series as I'm running it behind a pretty hot V8!!
Sent from my iPhone using Tapatalk
https://www.bigmacktrucks.com/topic/41829-12-speed-noise/
sounds like you have air leaking into the High Low part of the trans thru knob might just need a kit in it
sounds like the air isnt getting cut off properly or maybe the air rams have are binding and its not coming out of gear
Paul
https://www.bigmacktrucks.com/topic/41829-12-speed-noise/#findComment-304125
Paul
I agree, could be the shift knob.
https://www.bigmacktrucks.com/topic/41829-12-speed-noise/#findComment-304175
