My Electronic 95 350 makes 20 lbs boost. My 97 427's make 28-33 lbs of boost.
I thought 20 was low too but it is the specs of Mack and it pulls great. Service manager gave me the specs as we thought we had issues as well.
Gauges arent all they are cracked up to be either, I'd check gauge and see what specs are before trying anything else.
https://www.bigmacktrucks.com/topic/42012-how-much-boost/#findComment-305908
Might be a stupid question but to each his own.
What psi boost E6-350 should have when bobtailing?
Sure no load but with a full throttle at a midlle rev range it never takes more that 8 psi.
Generally in a flat road I see from 0 to 3.
https://www.bigmacktrucks.com/topic/42012-how-much-boost/#findComment-306016
  • 1 month later...
That would be about right
Brand new 631GC5117 turbo as per Mack specs
All systems good
Pulling tri axle trailer and grossing 41000 kg. / 90000 lb ?
On a continued pull I get 28-29 psi
And surprise a lot of new trucks when I pull past them
And still get 2.47 km per litre
Iam happy with that
https://www.bigmacktrucks.com/topic/42012-how-much-boost/#findComment-310178
The most I can get out of mine is 18-20
Sent from my iPhone using Tapatalk
I was wrong.
My E6-350 makes up to 8-10 on a flat bobtailing.
Recently I put a full throttle uphill on the top gear doing 50 MPH and saw 20 pci of boost.
https://www.bigmacktrucks.com/topic/42012-how-much-boost/#findComment-310287
