Hello everyone. Its a 2004 rb690s. Blink code 3-1 exhaust gas temperature.
FMI 4 voltage below normal or shorted low.
installed new sensor. Code came back.
checked voltage at connector for the guage 12.56v
sensor harness is not shorted checked with a meter.
I'm thinking the guage is defective?
Any thoughts?
Thanks again
https://www.bigmacktrucks.com/topic/42023-blink-code-3-1/
https://www.bigmacktrucks.com/topic/42023-blink-code-3-1/#findComment-305816
  • 6 years later...
are you talking about the pyrometer? I had an issue with a CV some years ago,  I installed a pyrometer that had a thermo coupler and gauge. I popped out the black plug that say's Mack on it , next to the air valves and installed it there,  I think I went into the EECM and shut off the pyrometer setting...  it's been a few years, but the pyro worked..  jojo
https://www.bigmacktrucks.com/topic/42023-blink-code-3-1/#findComment-484718
