My suggestion is why would two turbos spool up faster than one.Same drive pressure going thru two instead of one.You can put a turbo on from a smaller HP engine and it will spool faster and boost maybe more till it blows or has too much drive pressure build up and will not be able to over come the advantage of fast spool up.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306495
I understand how the smaller turbo spools up and makes boost until the exhaust pressure come up enough to have the larger turbo make the power.They take out the low rpm lag. Fabricating the plumbing fabrication is intense. What happens with the fuel delivery with the added low speed boost? I know it works fine with a gas engines. You can use a laptop to reprogram ECM's fuel curve. Question is what system its there for the diesel?
The system for the 6.7 Dodge-Cummins has a piggy back controller and a Fast Tune port for your laptop. Think doing a MACK, Cummins or other is un charted territory.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306504
There is an E-9 Puller on here running a twin compound set up. But the fuel management is way different for a street driven truck.
I would look into a Garrett Variable Vane Turbo Diesel as a possible alternative the the compound set up. Does basically the same thing as a compound turbo in a single unit. Might be better and simpler in the long run. Less plumbing and no real heavy injection mods. Paul
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306552
It has a mechanical pump, would u have to have wiring to tell the VGT what position to be in?
VGT units the intake aperture not the vanes are controlled by a one of the following. A vacuum actuator, electric servo actuation, 3-phase electric actuation, hydraulic actuator or air actuator using air-brake system pressure.
A few years ago Suprock Technologies released a VGT turbocharger controller that is capable of actuating any variable geometry turbocharger based on sensor parameters including pressures, temperatures, and shaft speed. This controller enables vehicles that aren't originally equipped with a VGT to make use of the technology for increased performance and efficiency. The controller is capable of calculating turbo performance based on engine and exhaust temperatures, exhaust pressure, air flow, and compressor behavior. The turbo compressor efficiency among other parameters that are displayed on a gauge pod located in the dash board.
The Garrett Variable Vane uses both rotating vanes of their design or the Cummins patented Sliding vane mechanical technology depending on application.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306622
They call them VGT's variable geometry turbos. The vanes are partialy open for greater air flow velocity on acceleration. When the vanes are full open you get max air flow
at higher power levels. On my 6.0 the max boost (vanes wide open) is about 40 psi. Being that its a 6.0 I never go over 20 psi. 6.0's like to be worked easy if you want them to last.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306660
Ford seems to have the best success with the VGT units both on Diesels and the Eco Boosted gas engines.
Getting a smaller turbo from a salvage yard is possible if you do a "compressor map" to match the boost verses rpm and Power bands. With out that the turbos will end up "fighting" each other and you'll lose power, economy and have emissions issues.
I gained most of the knowledge working with Ohio George Montgomery setting up my SVT Mustang. Went through the compound turbo verses twin Garrett Eco Boost style turbos verses turbo and an axial blower combo.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306667
Could I just figure up what turbo would go with a 056AP, and then look up what vehicles would have that turbo size?
Don't see why not. You could also call Garrett and see what VGT is a direct replacement for the stock one on your engine.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306837
It involves about 6 different algebraic formulas with this info plus more needed. Engine cubic inch. RPM, CFM, #PM, Ambient Air temp, Altitude, Barometric pressure, Flow loss through Air Filter, Exhaust temp, Exhaust pressure and Fuel use per hour, Air inlet temp, Air outlet temp and Power band desired.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-306968
I know what your saying, but I think it would be wasted on this type of set up. For instance, your engine should have a multi speed gearbox to keep you in the right hp/rpm band. I know in my truck, if I change up at say 1700, next gear I'll start at around 1400 and I'm making plenty of boost already.
But I'm not trying to talk you out of it, it would be cool to see something like that. And I'm always thinking of things I'd like to try, but I don't think you'd see much benifits.
P.S. Hope you prove me wrong.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-307000
  • 3 years later...
So I am in the process of building a compound setup for my 2v E6 Mack I believe there much tougher then given credit.... just gotta keep it up in rpm and not lug it ..... so I’m going to use a k31 as my high pressure turbo comes off a Detroit series 60 and a s480 as my low pressure turbo I have my fuel setup figured Out so my plan is run it till it quits if it does quit then swap out for a e7 mech engine. Mack truck are what I love but!!! Coming from building quite a few performance Diesel engines I can tell you this Mack’s air flow research has always been behind a k31 will much more air and move it much more Efficiently aka faster spook up  so it should be much more snappier and cooler running and and on the big end the s480 will take care I will take pictures when I start and give you a update how it performs
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-430043
Don't know what your end result is, work truck play truck or just a challenge.
As for spooling up and the time it takes, the limiting factor at least with a Mack is the Mack transmission if that is what you are using. The Mack trans will not shift until the engine winds down to pull it into a higher gear, it just will not speed shift and there is a lot of mass to slow down with big triple countershafts spinning not to mention slowing the engine RPM's. Forget about any shifting at all above 2500RPM's. An old Allison HT740 or 754 would be the way to go for shifting and once the turbo is "spook up" as you say it will stay there until you lift your foot.
There is a lot involved with doing a compound turbo set-up.  A lot of calculations and development to get a set-up to work every day in all conditions. Years ago there were a few compound turbo truck engines and the end result was to get more boost than what a single turbo would produce, like a 475 Cat and  2008 to 2014? Ford Powerstroke, the Mack E9 tank engine. Fast forward to today and it is EZ to get 60 plus pounds of boost out of the new technology aftermarket turbos. The new turbo set-ups are smaller twin turbos for faster spooling as boost PSI is no longer a factor to achieve. A nice new BW S480 turbo is about $1200 and more than most E6's can handle. Turbo lag has been reduced as the rotating mass of the new turbos is much less and efficiency is much greater than turbos from the 1970-1990's, when the E6 engine was produced.
Have fun but there is a much easier way to get more boost reliably, At least enough to blow head gaskets, scorch pistons and spin rod bearing. As for cool factor most guys would just ask why or say: It's a Mack "performance counts" just not high performance. By the way I think Staxx is getting about 1000hp out of a single turbo on his race truck.
Edited by AZB755V8
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-430045
I'm in the hater category when it comes to compounding turbos. They are engine killers. We lost a Liehberr at 4,800 hours because the secondary turbo blew and the operator ran right through it till the engine literally exploded. The sister turbo will make up for the second while its failing so it robs the operator of sensing the catastrophe onset. If you have a DPF your really in trouble, it will not even smoke before it explodes.
In your case you would see some smoke. When/If your secondary turbo goes it may start to ingest engine oil and your first turbo will give her lots of extra air so if it blows it may be quite an impressive show. Crowd pleaser at a truck pull.
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-430052
NICE! Probably  not  doing an inframe on that puppy! oops
  • Haha 1
https://www.bigmacktrucks.com/topic/42080-compound-turbos/#findComment-430095
