Fleet Owner / October 7, 2015
Ken-Tool has announced the introduction of the Ken-Tool 34555 Shark Fin Dual Wheel Separation Bag, engineered to help remove stuck and corroded wheels/tires from truck and trailer axles.
According to the company, the bag is an extreme-duty, rubber coated, nearly puncture proof Kevlar bag which uses air pressure to create 5,000 lbs. of force to separate and remove stuck dual wheels off the axle studs and hubs.
“Unlike any other dual wheel separation product on the market, it is safe for use on any wheel type – steel, aluminum or chrome – from 15- to 24.5-in. rim diameters,” the company said. “Stuck wheels are a growing problem due to the corrosion which occurs between wheels (particularly aluminum) and steel studs and hubs.”
The Shark Fin bag is inserted vertically between the tires near the 11 and 2 o’clock positions after the tires are off the ground and the lug nuts are loosened, the company noted. Compressed air is added the bag, using the attached 3 ft. inflation hose. The Shark Fin bag, rated at 150 psi, delivers 2.5 tons of expansion force at 87 psi, breaking the corrosion which prevents removal of the wheels.
The Shark Fin bag can also be used, with proper support cribbing, on steering axle wheels and inside dual wheels.
Deflated, the bag dimensions are 9.75” x 8” x 3/8” (25 cm x 20 cm 0.95 cm), and inflated, it expands to 5.5 inches (14 cm) (maximum), according to Ken-Tool. The inflation tube features a slotted cap for deflation.
