spring bushings are shot.
Sometimes its easier to replace entire spring set than just change bushings.
OR, just spray open gear grease into it to keep it quiet
I had a clunk appear in mine about a month ago. Sounded like someone tapping a piece of metal rapped in a blanket down by the right steer. Turned out to be the lower shock mount bolt had loosened enough that it was able to move a little. Couldn't tell by pulling on shock. Only found it when I put a wrench on and the whole bolt spun.
